I need recommendations for a reliable, street friendly 250mm disc clutch for a 2JZGTE. I'm building an offroad set up for which I don't need a fancy shmancy racing clutch that will hold a million horsepower. I'm just looking for something reliable that will hold stock power levels through a Toyota R151F transmission.
I will be using a modified Toyota flywheel, which will be similar to the stock flywheel in dimensions and weight. For a little background on the setup, I was originally planning to use a Toyota 1KD clutch disc and pressure plate. The same set up is already in use with a 1UZ in another vehicle and it works just fine. However, I'm concerned that the extra torque produced by the 2JZGTE will overwhelm the pressure plate's load capacity. Hence the search for a pressure plate with a higher rating that will support the increased torque output.
What are all the other JZ peeps out there running?
