service the rear brakes properly. The rear caliper brake lever must contact the pin before you adjust the cable nut. To do this, you should first start the engine and work the brakes so the automatic adjustment clicks in place.
Then verify the lever contacts the pin in the caliper assembly.
remove console for access to the adjuster nut, raise brake lever ONE click, adjust till wheels drag slightly, release and verify the wheels spin free. test the brake.
