Can someone knowledgeable please guide me in this matter?
-If you have worn rings, is it necessary to re bore the cylinder or can you just install new rings?
-Can you install oversize rings on original piston by filing them to make the correct fitting?
-What is a better option, re boring the cylinder and using over size pistons or installing a sleeve to stay on the stock size?
