[TABLE="width: 1158, align: center"]
<tbody>[TR]
[TD]
1. CNG Injection Reducer/Regulator, power up to 140KW or 5.0L, integrated with cng Solenoid Valve;
2. CNG Pressure Gauge: Send gas pressure signal to gas ECU to output gas volume singal(display gas level on micro-switch);
3. Mach Pro Gas ECU set(for 3 or 4cylinder cars, not for 5/6/8cylinder--another type): Electronic control unit, cables, water temperature sensor, micro-switch, map sensor.
4. Injector Rail-4cyl, 3 cylinders available;
5. Gas Filter: Installed after regulator and before injector rail to gas more clean;
6. High pressure steel pipe/tube: from tank to refill valve, then to regulator;7. Low pressure hoses: Gas hoses, vacuum hose, water hose and sylphon bellows
8. Mounting Fittings: Accessories for connecting, fixing and sealing these gas equipment on car
9. Programming cable: At least 1pcs is needed for new user; For gas ECU connect to computer to calibrate to reach a proper air-fuel ratio for different power of cars;
[/TD]
[/TR]
</tbody>[/TABLE]
