reply for deadalive ; a Honda Civic EXI 2005 model with 55litre cylender, what should be the maximum good milage in full cylender ?
with AC local and long route ?
Please must do advise ?
i will come to you in my next visit to pindi.
one more thing, in Liana suzuki put EGI (Electronic Gas Injector) which makes consumption minimum with better driving pleasure. can u install same in civic ?
i cant awanser your question regarding Maximum average , caus there are many factors to reach that leel ,
but according to the average filling of about 340 rupees in a 55 L cylinder it should do about 2 rs. a KM to minimum 2.30 Rs a KM
so according to this your car must do minimum of 160 (where the last 10 percent of your cylinder gas is wastage (gives no burning power)
a tip for all CNG users,
TRY ONLY TO REFILL YOUR VEHICLE WHERE ITALIAN COMPRESSORS ARE INSTALLED AT CNG PLANTS , FOR THEY GIVE THE BEST COMPRESSION LEVEL , AND BEST BURNING RATIO ,( just ask the manager , or cashier what plant is installed, AVOID FILLING YOUR GAS FROM CHINEZE PLANTS )
JANAAB , you are most welcome at our facility in Rawalpindi . it will be mine pleasure to welcome you .
im sorry to dissapoint you regarding the injector system , because it is out of budget for most of our clients , but insha allah , by next year, 2007 we will start importing it aswell , ( it costs at the moment about 450 euro's ,excluding taxes and other costs , so it is not feasible for the local market )
the rates are as following at the moment ;
Landi Renzo S.P.A.(096) model including 55 L cylinder with advancer and emulator (grip 2 grip) including fitting without holes, costs 34.999.-
including Lambda system installed costs 49.999.-
*rates include fitting Excluding Filling of the Gas Cylinder
