i have suzuki alto 2002dec i am facing a strange issue when i turn off my car its vibrate a lot and smell of petrol is coming and also approx 0.25l petrol is wastes in this process....this happens only when my car is on petrol ...not give any vibration after turning off the car on cng...as i am new honor and have not any knowledge about car i feel emberresed..
i am only able to start car 5 to 6 time on petrol and 3l petrol is wipe out...not drive my car to single km just start on petrol and convert to cng...aur petrol jahan air filter hota hai waha se girtaa hai
to filter pipe chang kro na, pipe main lekeg hogi ya clip thek se nai lagy hon gy
i think that the pipe which takes un-used petrol back to fuel tank, something is wrong with it. It's called the urrm return fuel pipe. Check for clips and check the hose too.
vibration kyn ati hai???pori car ignition off karne k bawajood bhoot tezz vibrate hote hai aur petrol girtaa hai
bhai jan timing adjust karwa layn CNG walay nai ap ki ignition timing ko bohat advance kar deya hai aysa naho kisi din koi valve ya piston jhunjhuna ki tarha bajnay lagay
Check float valve of carburetor for proper functioning,check fuel return line for blockage,check fuel cut off valve for proper functioning.
what are you trying to say tunnig kar waln?? and 1 chez mention karna bhool gya mera weak engine hai....smoke deta hai starting main.
