i presume you have added images for refenrence as the two are not compatible in fitting. The led light will fit where this bulb fits
If your bulb was 12v, and led is for 12v then it should work. Check the light cavity for dust/dirt. may be its blocking its way. Also check the voltages at the holder, it should be around 12v.
