Salam,guys im having a 2500watt Loncin generator and generator is not taking self so i took suggestion from other guys and they told me that solenoid (ghuggi) is not working.. so i changed the ghuggu and it works on that day battery was low so i put battery for charging and put new battery but ignition is slowly moving the starter motor and motor is not moving the flying wheel i thought it was problem of starter motor but when i run starter motor directly on that battery it works fine and engine get started and battery get charging also i do not no whether it is a problem of solenoid or may b i put some wires in wrong position please help required and will some one give me wiring chart for solenoid
