+1
Sent from my A60 using PW Forums mobile app
12 is too less, my margalla could do 12 to 12.5 even with a worn clutch and bad distributor cap and rotor, your car is a 3 cylinder, it should do more
Start kro yar swap.eid pe enjoy krna
Nai yaar, don't try to do it too quickly, do it once and do it right, to do it right, the owner needs to give alot of time
My mechanic is quite busy these days. Wo visa wagera k chakron mein hai . He is going abroad for some days that's why he isn't giving any positive signal for the swap job. He might take this job after Eid.
And I've scarcity of time due to busy schedule. Will work on this after Eid as the mechanic is also busy these days.
I don't know why it gives too less in local whereas on highways, it gives me pleasures and saves good quantity of fuel.
On highways the magic is due to fifth gear, rpm reduces for the same speed in fifth gear which saves fuel
Wont somebody try installing Honda 125 carburator to save fuel kion @margallar
Don't know about 125 but some cabby in Pindi installed CD70 carbo in his cab to save fuel.
Exactly.
dont try that to save fuel this efi engine is going to make you love your car and easy to maintain. no hiccups on petrol or cng. Only if you could make it rite
Afnan bhai I dare you to come see how smooth my carby car is
Seems you have not allowed these mechanics to play with your carb
Sent from my HTC One using PW Forums mobile app
Got a virgin carb from bilal gunj, fixed its hoses with osama bhai, then renewed the ignition system, and then fiddled with tuning, still think changing coil and generator will make it even better
g10 carby makes less noise whereas the efi is noisy at same rpms..i havnt found out the reason for this..@OP best of luck for the swap just be extra carefull with the wiring part.
@margallar whats with the noisy tappets with every g13 in margallas?? my carby that has clocked around 195k on the odo without overhaul has started to make the same noise from tappets until recently but only on cold start ups..changing oil grades doesnt solves the problem..wats your take on this??
seems low on oil or weak oil pumpwhich oil grade you are using??i found 10w/40 the best oil for carby cultus
How much did you pay for that virgin carb ?
Thanks a lot. Will start the swap after Eid inshaAllah.
