Subsequent to you post on this, was looking around for an email I received fm LM a while back regarding using the MoS2 in a flat tappet rocker config like in the Cuore. It is an SL oil, but has enough ZDDP in ppm to support.
Appending below:
Quote
Dear Mr Ali,*
for this car we would recommend you to use our MoS2-Low-Friction 10W-40. This engine oil contains solid lubricants and a ZDDP of about 1015 ppm.*
In the attachment you will find the product datasheet.*
We hope we could help you with our informations. Should you have further questions regarding our products we would be very pleased to get contacted from you again.
Mit freundlichen Gr??en / Best regards*
i. A.Andreas Zahner
Anwendungstechniker*
application engineer*
Unquote
Sent from my GT-I9500 using PW Forums mobile app
