A weak compressor may be the culprit.
Reducing the gas should do the trick for you at the cost of a little lesser cooling.
Ultimate solution will be to change the compressor or have the bearing replaced if it is replaceable.
With just a month left of AC usage, I suggest you do not have the compressor opened since there are high chances it will be beyond repair and you'll end up changing it.
