Dear all,
i have 2004 chev exclusive its my first car and now engine is giving noise and mechanic says its Main Beign sound and use thick oil, Engine is not reducing oil no smoke performance is fine now tell me what should i do
Last time i was using 10 30 Havoline forumula one which is thin and now using thick oil GTX kindly suggest me which oil i need to use and for main Beign sound mechanic says you need to overhaul the engine or Use thick oil but at last u need to overhaul
The Main beign sound problem was occurred in 2013 september after that till now still i am using the same engine.
please suggest me can i fix this issue but using oil???
I am from karachi any help would be greatly appreciated.
do i need to overhaul the engine any best mechanic ??
there is no CNG in the car .. only runs on petrol
