2 days ago i Parked my car out side and came back and saw a big puddle under the car about litter or so... At that time i couldn't find any problem and refill the radiator drove back to home then immediately open the coolant tap carefully and there was big pressure water came out like volcano...
Before all this if i drive car all day and open coolant cap there wasn't pressure overflow at all because i opened some times before...
I'm worried about this much heat and pressure overflow and before go to mechanic i thought would be nice if get some guide from you gurus if it is water pump problem then i could fix it myself.... What you think could be the problem other than pump
During drive heat gauge stays little down below the half...
But I'm worried about pressure overflow now it is winter but in summer it will be worse and more pressure i must fix it in to previous condition
Thank you
