It has a worse than awful ride. Drinks fuel like anything. Otherwise it's a fine car. Owned a brand new one for almost 2.5 years
Guys, please take the flame wars elsewhere. I would appreciate if we all stick to the topic.
I believe there is nothing more childish and immature than expecting the world to agree with one's opinion and then marching around trying to enforce the same opinion on everyone else.
Peace!
Sent from my SM-G900H
I have faced the same issue on many cars. Its Fungus inside the vents but never found a solution to it
And Sorry for going off-topic before
using germs killer spray on the vents and inside from there the suction process goes on is the solution to that. i will visit sitara market today to see what they have got new in stock i was gona buy pressure air can to clean my ac vents. i will see what i recommended in my earlier post to @s_ruhail if thats available i will buy it for him. Lysol Germs killer spray se masla hal ho jaye ga. na koi smell rahay gi or khushbo bhi ho jaye gi.
Lysol = dettol spray
or any other disinfectant
Thanks brother, that would be a great favor!
Try and get a proper odour eliminator.. @ahmad_yar bhai might be able to help you..
It comes sometimes and its quite irritating, ill try to look for Lysol
is it done? have you fixed your issue? or still looking for the spray?
Found Lysol at Agha's.Bought 2 cans.
Has improved a lot with spray and hot air once a weak with heater setting.
However, I think car doesn't properly seal off outside air on recirculation.Will have it checked by dealership.
The smell isnt coming nowadays, got normal all by its self
haha germs lagta hai forums par rahay thay hamaray
lol...
Update: the problem seems to be solved after adjustment of fresh air/recirculation mechanism. Also added a new cabin filter and so far no stink. Breathing easy!
What was the adjustment of fresh air/ recirculation mechanism and how was it done?
Bump
Check you A/C condensate drain pipe that it's fully open and not clogged.Get the evaporator cleaned through any good good A/C workshop.Replace A/C cabin filter.
Thought I'd update on this: the ac condensate drain pipe was disconnected. Dealership didn't admit until I barged into work area and saw it for myself them showed them.Had it fixed, been a few months, going fine.
Thanks all for your help!
