Aoa memebrs i recently swapped d14z2 (1394cc) engine with d14z2 injectors and manifold in city 99. but i used my old pakistani ecu p3x-k01 which came with 1.5 d15b2 engine . problem is that i m not satisfy with wheel speed . Engine is in good health compression is ok but it feels like engine pulling load like " khul k nahi bhag rahi " . when mechanic fitted the engine he didnt change the spark plug didnt valve adjustment he didnot see timing belt condition . stock plugs were bosch single tip ..
problem is i m not satisfy with the acceleration on wheel. it goes to 120 at 3.5k rpm .. clutch plate ka bhi issue nahi lagta. albata aik bar timing gun se ignition timing darmian wale mark pe set krwai to engine knocking kerne lag gya.pulley pe tdc mark k pass distributor adjust kia to knocking gayi ... stock pulley mark pe knocking thi what should i do
