Is it food to do tuning from suzki s3
Aoa guys, need some guidance. I have baleno 05 JXR, swapped engine with g15a back in 2014 alongwith ECU and transmission. Car was going good but last year it started to lose power due to random RPM drops. I went to suzuki 3s and another good workshop in lahore but they couldnt even detect the ECU. need help cuz i have located the fault after alot of trial and error. Fault is in the communication between TP sensor and ECU but cant find a good workshop where they can detect the ECU and configure it to optimum settings. Please suggest a good one in lahore. I would be grateful.
Guys, please suggest me a good mechanic in Islamabad/Rawalpindi for suspension work of Civic EK. Looking for someone who has experience of working with Honda cars and charge reasonably.
Can anyone suggest best workshop electrical n mechanical near Gulshan Karachi
Aoa, Guys: Can anyone guide me on following issue:Few days back I had my liana's clutch, pressure plate and bearing changed. After that I have noticed that ABS brake light remain lighted up all the time. Before it used to go once I start the engine. Thanks in advance.
I recently Bought 660 CC Suzuki Alto 2007 Japanese Model, the car is giving 7 km/liter and different sounds are being produced from belts. I want to have its general check up and get it tuned. Can you guys please recommend a good Mechanic?
Saeed Engineering Works, Gawamandi Rawalpindi. Best,reliable and tested!
Someone told me that they are very expensive
Workshop Name: Sadiqabad Auto WorkshopWorkshop Picture:Workshop City: KarachiWorkshop Address: Baloch Colony, Near Shahra-e-Faisal, Opp PAF Falcon ComplexSpecialty: Mechanical, Electrical & A/COwner Name: Hassan NadeemEmail: sadiqabadmotors@gmail.comPhone: 03337412844
As per the recommendation in this thread, I also went to Irshad for check engine light problem, he was unable to diagnose the problem he made me change cat. converter, o2 sensor, body throttle still light is there wasted around 25000 rupees ....
was it scanned for errors.
any update
Dear all. my fj has encountered an issue. its not burning fuel properly, alot of fuel fumes are coming out from the exhaust and causing massive fuel consumption. can you guide me from where should i get the carb tuned up? in karachi.
thanks alot for the prompt reply, can you please guide the location as well. thanks
Carb fixed . Found a real gentleman zi his workshop is opposite parsi gate near nmc. He diagnosed the problem in 5 mins and fixed in another 5. Other mechanics were recommending change of carb or servicing it completely. Two thumbs up for Mr zia
Sent from my SM-G900H using PW Forums mobile app
Subscribed
My experience with Mr Zia is excellent so far. he fixed my carb in no time and now he is working on the brakes. every one was recommending a disk conversion but not him. he wants to fix the issue not replace or upgrade unnecessarily....because i was very happy with the drum set up........... will update when he is done with the work............
location opposite parsi gate near NMC karachi
The brakes are working fine now.....lets see
