My city 06 (3500 kms driven) is giving brake noise.. when u press brakes it gives (tak tak) kind of noise from rear left side wheel.. noise comes only when u press brakes till car stops..what could it be? worried
i would get it chked asap from mech before further damage. sounds like rotating object is hiting a non rotating one, and its not supposed to. ,,(maybe something stuck there which is not supposed to be there. cannot tell further without opening it.
levin bhai is right. may be koi spring nikal k phans gaya ho. wesey thak thak say lagta hai k brake k jootey (shoes) apni fitting say loose hain
@ levin
bhai hows ur foot/ toe now??
thanx levin ill get it checked soon
@oodbalow yes it seems it is some kind of brake shoes noise.. it only started when i had some hard braking recently in some emergency.. may be they need some adjustment.
hasan i was having the same problem so go to the honda showroom where it can be checked .don't go to any other mechanic other than HONDA SHOWROOM YOUR CAR IS IN WARRANTY .IF u will go to any other mechanic the will jusst open the brake shoe and will rub it then sound will not come gfor few day but afterward it will come again and then u will have yto go to the same mechanic and now he will say that ur(app kay brake shoe shakht ho gahay hian) uwill have to change it and it is an opportunity for the mechanic he will replace it with rs 500 and will take the orginal brake shoe .the original brake shoe cost about RS 2000- 3000 depends .so go to the original showroom and i think that ur car is in warranty that why ur labour will also be free
Hello!as far as u said "TAK TAK" noice so it can't be brake shoes......Brake shoes or pads alwayz make Squeals when they have had Hard or Cheap Liner Used.........and mostly fron't brakes squeal much more than that of rear ones...rear one hardly squeal as when they..its time for a change......i think this TAK TAK noice was something different.......get it checked by Honda 3S.......!!if they are brake pads...thats disgusting.....3500km worn out :S.......if there else.......it can't be on newly 3500km driven car...Strange....!Thanxxx
soeey i havent read the word (tak tak)i think may be of suspension
get it inspected ASAP. no point in wild guesses.
does the new honda city has discs on all four corners or the rear are still drums?
I second @Spectra! Either get it checked-up or stop driving it unless repaired.
I had the same prob in my FX and all machanics have different stories to tell and i spent about 5000 rupees to control it. But it continue and later it was found the brake cylander was broken. I t was replaced and noice finished.
i had that problem with my cuore that same "TAK-TAK" when u press the brake, i showed it to my mechanic all he did was, clean up the disc and buy new pads, if that dont work for u buy a new disc, as far as i know it the disc!
