I have a cultus and recently I got my steering re-done and hence the wheels were opened, after that , the brakes were not working at once they took time to stop the car.
Luckily I realized the problem right away and told the mechanic, he did something which i did not understand. All i know is, he pulled out the brake fluid cables, and some brake fluid came rushing out, and then he put it back, on both sides. And the issue was solved and the brake became perfect!
before a few days, I got a stud replaced and so the brake was opened again. And now i'm facing the same issue again. I noticed today that the issue increased and now the brake is even lesser effective.
Can somebody tell me what the mechanic did by removing the brake fluid pipes and putting them back? or something else which should be done to fix this? If its just removing the brake fluid pipes and putting them back, I'm planning on doing it myself
Click here for SOLUTION
