Did not remove the thermostat valve Shell helix ultra Injectors cleaned every 3 months Check light is off at the moment..
Check light working fine.... Done what you told me....
Done everything bro... Except for the fuel filter and pcv valve....
there is your problem. - who told you to do this?
and has anyone messed with the trim pot in the footwell?
So what's the fix bro...??
But bro the injectors are new... And it's been only 4 months... Got it cleaned just once the old injectors were causing the car to miss all the time... The pick was next to nothing at that time...
Trimpot of footwell.?? Could you send me a pic so that I could remember if he screwed with it or not...
You might got bigger injectors if purchased from scrap market. There was a thread in which member faced such problem, they took an fpr and adjusted the pressure later he replaced the injector and problem solved.
you claim that the injectors were cleaned every 3 months, then say that they are new - (I dont quite beleive that new injectors are sold in Pakistan)
The injectors installed were not brand new... But they were the fix of my smooth drive and pick up problem ..
