My sweet fellows . i just want to ask that what can be happen if my car's plugwires are not able to use any more.is it effect on pick.?if yes then plz tell me the detail.and also tell me about the Qualities of plugs wires.i means which one i should use for civic 95 ex.
Sweet LOLZ
Itna pyar nahi do . LOLZ
bago bago ye humeee sweet kae ker bula ra hain bago bhio bago dor bago
acha sorry i should say my bagharat fellows. plz reply me now..
Edit by mods please Avoid Bad words
if any of the plug wires is short(or having some sort of problem)u will notice missing in the car. second hand markets are flooded with plug wires. go for the genuine ones
@ nomeejee
my sweet n dear deer bhai
plug wires kharaab hain to koi masla nahi bijli ka taar laga lo 7/44
the following are some problems you might face.
Erratic idle lower engine performancelow fuel milagestarting problems and others
yes bhai . i am facing all this problems . So i should change my wires now or how if i buy from Bilal jee gunj .?
You are not going to save any money, they might turn out to be bad too. It is better to buy new ones. they will last you longer.
ok thanx . ok would you tell me the cost of new ones. that i buy right thing.
Well not sure how do they cost where you at but your local guys might be able to help you on that. And it would be nice if let them know what car you have and what kind of wires are you looking for expensive one or cheap?
Hello!better get it checked from multi-meter...check resistance b/w two ends........set resistance to 20k and check...if its slows like 2-5k...the wire is good....!if its more than 20k..means a wire neeed change.......!if you won't know...take plug wires to any auto-electrician ...he will check that.....also to a person who uses multi-meter...its easyThanxxx
