Guys, I am thinking of adjusting my Corolla's high beam so that the HID light does not directly hit on coming traffic. By doing so, will I still get the same light and performance by the HID's? Thanks,
i wouldn`t recommend altering the factory settings, if not annoying oncoming traffic is your concern,you could either take them out of the high beam and put them in low beam or not switch them on at all
Thanks dude!
As per OEM specs HIDs are fitted to the low beams.High beams are almost always normal. This is the case with almost every imported car i have seen fitted with HIDs. Shift them to your low beam.
