Engine
Type
Water-cooled, In-Line 4-Cylinder
Engine Block
Aluminum Alloy
Valve Train
16-Valve SOHC i-VTEC
Fuel Supply System
Multi-Point Fuel Injection
Throttle System
Drive-by-Wire
Bore / Stroke (mm)
81.0 X 87.3
Displacement (cubic cm)
1,799
Compression Ratio
10.5 : 1
Maximum Horsepower (bhp @ rpm)
140 @ 6,300
Maximum Torque (lb.-ft @ rpm)
128 @ 4,300
Ignition System
Direct Ignition System with Immobilizer
engine same.
Door Mirror with Integrated Turn Light
ivtec may nai....
CD Changer with CD Bus
ivtec may nai....
yea b nai hai..
Fog Lamps
yea b nai hai ivtc may.
And Sunroof b nai hai..
Baqi In dono may koi diffrence nai hai...
