when i start car the oil light lit up and after few minutes it off. when i stop the car it show off and when i run the car its goes off after some minutes. I have checked the oil and add further in it but result is same. solution please
after few "minutes" or seonds?
if seconds, den its normal.
What Car?When was the last oil & filter change?
1: After few second or couple of second :
man the light is on for 2 or 3 seconds then it turns off in my civic. Well let the oil circulate around the engine yar.
not bigge problem tension not if only 2 or 3 seconds
@CAR9 it is not a problem if the oil light stays on for a few seconds. But if stays on longer - there can be an issue - if you dont have an oil filter learkage, it could very well be your oil pump.
facing the same problem in my santro 05, 95k kms driven.here is my thread,https://www.pakwheels.com/forumreply_az_TopicID!108458~ForumID!10~pw.html
now confused, that is the actual reason for this.
