palaykhan: Best use for it would be a turbo engine or at least sc type.
N/A setups are designed to run N/A .. you would need to change lotta stuff to add full power of turbo. this has been discussed so many times issues of going to turbo setup from N/A.
Especially the damage of turbo surge . overboost leak. you drive a fwd car,, cant fix it with a jz series swap either. but yes, turbo is possible when done right.. i would leave it from here to racerf2 to continue ups n downs and what is required.
maybe he'd be there at meet yu can ask him direct:)
if the question about ,,,should i buy strut bar, the answer is yes. i try to come or will ask libra to collect it as you be seeing him soon
