@viking
mobil1 is available at optimum motorsports zamzama,likun udar takreebun 2400rs tak milayga! if uve seen makro superstore which is located at site udar ull get mobil1 for 2100rs! ELF is even available at optimum motorsport and liqui moly ull get at racer,thts the shop rite next to optimum motorsports!haan mobil1,elf and liqui moly original hee milayga ais jaga say!n try 2 get a decent oil filter for ur car...which car du u plan on pouring it into?either purchase a bosch oil filter or a k&n oil filter...yet once again ull find these filters at optimum too!ive been using mobil1 in my alto vxr 06 n it seems 2b doing quite a fine job! so far ive used the oil 10,000km and its still clean..i get the filter changed after every 5k!n the oil filter that im using is by bosch!so i can extend it even up till 8k likun to stay on the safe side its better 2 change at 5k..where as other local filters such as guard etc only last 3k max!m quite happy and satisfied with the results tht mobil1 has given!b4 this i use 2 use shell the blue packing wala tht was crap!ever since ive started 2 use mobil1 cng par starting bee baytareen ho gai hai and performance too!so mobil1 all the way!hats off 2 mobil1!
yaar it depends which sparkplugs u want?coz variety to bhoohat zada hai bosch,ngk,splitfire,HKS,autolite,denso etc etc etc and the list goes on!if ur using a cng car go for bosch super4 ive been using them since more than 1 year now performance on cng is flawless!i mean starting b sai hai idling bee sai rayti hai etc etc...n first self mein car start hoti hai cold starting par!
