Hi all, i have noticed this sound of khat khat/tuc tuc sometimes while turning the steering left or right. Any explaination plz ??? I have Cultus VXR 02.
It may be ur axel.
time to get the axels of ur car replaced or repaired .
It can be the thrust washes on top of shock absorbers as well if the sound is low. If it is loud and clear than axles.
Get ur car some new axels
steering rack needs replacing
Sorry, i did not mention that sound comes from steering and not from axils, so steering rack may be a close answer. Anybody can explain further about STEERING RACK. ?
Get it checked from a mechanic.
All possible answers ahve been given.
Put new axel in ur car..
its not axel yar....does it comes while u give indicator and then rotate ur steering?does it come when u try to rotate ur steering while in rest position?Well if the answer to my 1st question is YES and for 2nd one NO, then its ok. its normal in suzukis...dont worry...
well i got the same problem in my suzuki mehran 2006.while u drive for about half an hour or so then suddenly the tak tak sound comes from sum where axle or steering rack but dont know where its cumming from.ive take my car to mechanics though but they also dont know wots wrong with it.and they say sir the car is fine.nothing wrong.
@mithu u also read my reply above urs
@bubblewell ive read it already but the problem is that my answer to ur first question is NO and my answer for ur 2nd question is YES .cheers mate
Well i think the steering rack should be like this
and this must be the (the suspect ball joint and bearing (arrowed)... )
and this must be the ...ball joint dismantled for inspection.
Yea its da AXLE coz da tuktuk sound also cumz frm ma MEHRAN while turnin da steering wheel nd da mechanic told tht its da axle
The problem could be with the steering rack or the velocity joints. If the sound comes while the car is static then it's the steering rack, and if the sound comes while turning the car while in motion then get your velocity joints checked.Anyhow get a good mechanic to have a look on your car.Regards.
lolz now wot the hell is that velocity joints ??? when things got settled down then at a sudden another problems comes up.poor suzukis ...
Tuk Tuk is the name of the rickshaws in Thailand.
lolz we also got em here in the shape of suzuki's
The tuk tuk sound indicates that its time to get a new car or ur car might like Tuc Biscuits..lolzz..My friend's mehran also produce tuk tuk sound when he turn his car's steering and drive...nd that sound cames from his car's axel..
