its probably LPG and not CNG.
It is used as an add on in the air intake of the diesel, the engine does not run purely on LPG. Its meant to give extra power (minimum 10%) and better fuel economy (improves diesel burn rate). But it has to be carefully monitored, otherwise you can damage the engine.
