Yes u can change ratios. Gear ratio is obtained by dividing the spur gear (the bigger sprocket) by pinion gear (the small sprocket). It is easier to change pinion gear.
Spur=90
Pinion= 22
Gear ratio= 4.09
So its clear that by switching to a larger or smaller number of teeth on the pinion will make the ratio lower or higher.
