i hav a 1.3 lancer 2006 n im thinking to put 1.6 block in my 1.3 i wont need ny other changes cuz everythings the same but some 1 told me tht il always b having oil leak prob is tht true or will there b any other harm to the engine
@ahad: why dont u swap the whole engine? like 4G92 mivec or 4G93.....well i ve 1.6 lancer n i think u wont get more than like 10 to 15 hp to change the block, these engines r almost same only displacement is different
i think his car is boosted, he wants to change the block to the 1.6 one, so it can handle a bit more boost and hence give more power then it currently gives...
and he cant do a whole engine swap, so this is his best option, am i right Ahad?
hello hybrid engines donot last much longer and the performance gains are not worth it . If u want the cheapest way to make power, feed the engine with some n2o
@ahad89you would also need to change the fuel pump.
also oil leak problem will be there...until and unless you change your fuel pump.
