I have a Suzuki Cultus VXR with 10.2mm Redline plug cable and Bosch Super 4 plugs. I have instaled 3 cables from distributor to plugs and they are workign fine but when i am installing the cable from ignition coil to distributor then my car RPM trips after 4000 suddendly to 2000.
What can be the pausible reason behind this issue? Currently i am using the stock cable from ignition coil to distributor and it is working fine.
Secondly I have also installled simota air intake and my car mainly use CNG but it suffocates at high rpm whereas on petrol it flies any good mechanic who can fix this then kindly give me the contacts. I live in Karachi.
Adul Basit
