Hi...
I am having problems with my CNG kit. It just turns off for no apparent reason and when i turn off my swith and turn it on again, the kit is turned on.
Anyone has a solution to this?
the switch turns off?the car shut downs?not clear :S
@Iam Waqar, Sir konsi car hai apke pass ?
I have a khyber. Turns off meaning the engine turns off.
Two things to be checked. Solenoid at the kit and switch inside the car.
@spectra
The problem doent occur often. Its once in a blue moon story most of the time and when it does occur it occurs every 3 to 5 minutes. I got it checked from a CNG mechanic and he cant find the problem as it didnt occur in front of him. I dont know any good mechanic here in Lahore, if you know someone i can go to then do let me know.
thnx
cylinder mein gas khatam ho jati hogi!
lol
@Mr1derful
My car refills itself once i turn off and than turn on the switch as i've mentioned that once in turn off the ignition and turn it back on the engine resumes power
