@ dream gal
little sister, again No thanks
ye4s if u r air filter needs 2 b replaced or cleaned u must do this......no matter its cng or petro
abouyt fuel filter, u must know filters fuel, so as ur car i think starts automaticaly at petrol but uses gas for most working so ur fuel filter will hav more life, if ur gas does not move through that filter then its use is very less, as its less so it will xpire late/v late
but again som mechanic used 2 say in old times:
if u feel som prob in such matters then put max mixture of Hioctane n run ur car on som Highways, this fast usage of fuel will movew som dirty particles out easily, that may b stying inide som filter etc.
i think this is a good trial, but can u tel that is ur car facing any problem due 2 fuel filter? or a mechanic asked u to do so? is ur car an auto car or manual?
as ur stress is on FUEL FILTER then i think there is som issue, kindly giv som true situation so that v (any1) cld sugest somthing 2 u...
bcoz 1ce ma father had problem in car, honda fort guys just asked him 2 change fuel filter, but that was a Relay problem,,,, such people just ask 2 change/replace without trying 4 repairing/seting etc.
Batery:
there are things in car that can create prob 2 batteries, but if u take care, regularly check water level (plz use recomended water wich has usable particles or does not hav non usabvle poarticles) and terminals consitions (wash with hot water if there is som white DUST), if ur batery gives problem regularly discus with som good shop keeper then replace it,
well som poeple say: if a batery has 1 year waranty then it will definaterly work for 1 year bcoz they know their batery will giv problem after 1.2yrs, so a good time can b 1 to 2 years depending upon ur care, if it gives problem, then don make it repaired bcoz localy repaired are not good for good cars specially EFI, they can giv som spark type problems which is dangerous for Computers for EFI cars,
u said: Really thanx a lot for this kinda helpful information..as am lady driver any one can make me fool so these kinda tips will help me a lot
I SUGGEST u to regularly check such topics on PakWheels.com n discuss here if u r 2 make a big decision, n yes (example) NO 1 if seling Tires will tel u that a wider tyre will only giv better grip, but ngine will hav 2 use more power, suspension will face prob, power steering seting will b effected as it has been set on specific tire size or may b effected etc etc. BUT HE WILL JUST SEL U N SAY IT WILL B GR8 DEAL FOR U.
so v r always here, u can even cal me anytime 2 discuss anything if u hav som prob deaR sister,
@ green beret
yes it can b right
but v may need same thing b4 that, or somtime after also,
wel v must underrstand that many things take parts in making parts in good condition, specailly Rings, seals if they r not moving oil forward
e.g.,
well
keeping seeting ok it can make 2 20k inb conventional ngine
but in latest cars it can make 2 40k also,
but plz keep on checking through som good person,
in case of high tech ngines som people even check asfter 10 to 15k kms
in
