@dot3
the most important thing is dat the oil level shud be maintained and if oil level drops u shud refill to the level and change the whole oil on time
and u shud check it with ur mechanic as when piston rings become defective, they allow oil to pass piston and burn away so check it as ur engine will produce smoke it is the last stage and u will hav to pour more oil to feed engine
