Hey, I've got a technical question about turbocharging.
I've heard theres too types of Carburators, Vaccum Negative Pressure Carbs and Blow through carbs. Can u tell me that will a Blow Throw carby insert more fuel according to the turboed compressed air it is getting.
I mean that, a normal carby, suck through cudnt work on Turbo. SO, if a blow through carby is used, the turbo wud be adding more air so the engine will need more fuel ! Will the blow through carby itself add more fuel to the engine according to the extra air its getting????
ANd yah, what other things I'll require if I change the suckthrough carby to blow through??? Take any carby car and answer ma question plz?
Cheerz!
And yah, I almost forgot, what could be used to limit the boost? I dont need electronic ones cuz they are damn expensive! But tell me what to use as a Bleed Control valve and wud I be able to use it as a Manual Boost Controller!
