google my friend google!!! ... learn to use it
wht is meant by max.output.?
wht is meant by max.torque.?
what is the max number of straws you can stuff in your mouth ? ...
the questions should be what is max output and what is max torque ..
max output is the maximum horsepower produced by and engine
max torque is the maximum torque produced by an engine .. .what is torque? twisting/turning force produced by the enginge is torque ...
wht is difference b/w CC and litre?
cc is cubic centimeters ... 1000cc is 1 liter ... this .. if a civic is 1.5L it is 1500 cc
wht is meant by sturt bars?
a strut bar is connected to the strut towers to give extra regidity to the suspention.
wht is meant by coil overs.?
a damper with a coil spring over it is called coilover.
wht is meant by chasis.?
chassis is a frame that supports the body engine gearbox blah blah .... your skeleton is a chassis ...
wht is meant by psi of turbo.how we calculate it.?
psi=pounds per square inch .. it is a measure of pressure ... a turbo is tuned to a certain level of boost
wht is meant by WHP.how we calculate it.
WHP is wheel horse power ... which means the power that the engine is delivering to the the wheels .. it is calculated on a dynamometer ..
also explain da classes of mercedes ( S , R , C , M , A , E CLASS)??
http://en.wikipedia.org/wiki/Mercedes-Benz#Models
S class is the largest car merc produces
R class is more of a van
C class is small sedan or sports coupe
E class is the midrange that slots between S and C class
M class are SUV ... something like range rover
G class are SUV's but are more of land rover deffender ..
A class is the smallest car made by merc ... its subcompact car ..
B class are somewhat the same as A class but more powerfull and sporty ...
i was bored enough to actually wire all this crap .... yep =\ ...
