bhai 35000 key gaaree pay tum 2 lakh kharch karo gay.
be practical man.
waisay agar drift karnay ka itna hee shauq hai to aik jugaar hai.
Kehtay hein kay tyres hee gaaree key asal grip ko reflect kartay hein.
Simply play with your tyre pressure.
trust me, this is the first place you should be looking to modify your suspension setup. you do not need adjustable struts and dampers to start setting up your car.
Haah you'd be laughing by now. 120Y mein suspension setup. Bhiyaa kisee bhee gaaree ka suspension setup us kay tyres kay pressure per directly depend karta hai.
acha back to drifting.
This may sound odd to you laikin.
25PSI in REAR TYRES.
40PSI in FRONT TYRES.
if you are using 145/70R13
thats my setup for an easy drift.
acha 40PSI agay kyun. 30 to normal pressure hota hai.
bhai 40PSI pay tumhaaree gaaree ka frontal center of gravity kaafee hud tak seedha rahay ga aur gaaree side to side squat kam karay gee. This also means kay tyre ka contact patch barh jayay ga which means better grip and no understeer.
Acha 25PSI peechay tyun.
this is to reduce the contact patch and add some rolling resistance. laikin jub tum drift start karo gay to tyre temperature barhay ga aur dangerous levels tak pohanch kar explosive bhee ho sakta hai agar mein ziyada PSI batata. is mein tumharay pass drift karnay ko ziyada time bhee ho ga and you'd be on the safe side also. This is to induce Oversteer baaqee front tyres mein pressure sahee hai to gaaree pakar sako gay slide kay dauraan.
laikin make sure that your sway bar is absolutely secure in place.
happy drifting.
