Results 1 to 9 of 9
Thread: help needed ,,,,,,,,,,,,,,,,,,,,,,,,'
    muhammedali's Avatar
    Feb 2010
    28
    1,071
    2 Post(s)
    Default help needed ,,,,,,,,,,,,,,,,,,,,,,,,'
    salam to all pakwheels......
    i have suzuki kei model 1999 with intercooler turbo ...... 90,000km done. then the intercoler turbo r not working properly.. thats y engine is overheating so please kindly help me ......
    k main kya karo mechanic says k repair nahi hota ... kisi ko koi place pata hai jahan se new easily available mil sake ya koi importer jo japan se import karwa de please kindly help me
    Feb 2010
    28
    1,071
    2 Post(s)
    at karachii
    Feb 2010
    28
    1,071
    2 Post(s)
    any 1 ? ? ?? ?
    VCheng's Avatar
    May 2010
    Select City
    25,479
    7
    434 Post(s)
    4 Thread(s)
    So is the engine running but not well? How bad is the overheating? Is it loosing oil and/or coolant? Any smoke from the exhaust, and if so, what color?
    Most engine problems can be repaired I would think.
    Feb 2010
    28
    1,071
    2 Post(s)
    thank 4 reply sir ...... \
    ys engine running but not well means pick of the car very down .
    yes it is loosing oil
    and white smoke cme from the exhaust system
    n khi i would check and search some mechanis but ...... problem nt dissolved yar
    can any 1 tell me the superb mechanic in khi to treat japani cars ?????????
    ghufran_sidd's Avatar
    Aug 2008
    32
    17
    hey buddy u will go to behind capri cinema there is a mechanic whose name is ASIF and the shop name is POONA AUTOS u may go there and tell the problem he will give u the remedy of ur problem his number is 0333-3187001.
    Feb 2010
    28
    1,071
    2 Post(s)
    thanks yar
    VCheng's Avatar
    May 2010
    Select City
    25,479
    7
    434 Post(s)
    4 Thread(s)
    Quote Originally Posted by muhammedali View Post
    You likely need the engine completely overhauled.
    The power is down because the turbo is not working properly, and the engine is generally worn out. It is burning oil because of worn rings, bores and pistons. The white smoke means that the head gasket is leaking.
    I do not have the local knowledge to help you, but it may be better for you to get a replacement engine vs getting this one repaired, depending on local availablity and your financial situation.
    wasay_ahmed's Avatar
    Nov 2006
    29
    4,959
    12 Post(s)
    as vcheng already suggested Swap is the best option although u must simply swathe engine although swap the assembley only along with turbine
    DIY The Best Workshop on the Holy Planet!
    Every thing changes,Its only the "change" which never changes.
