Sir
There is an Every, every Wagon and Every Plus.
2002-03 Every wagon has a 5 speeder manual, DOHC 3 cylinder 12 valve 49 PS EFI .7L K6A engine.
165/65 R13 tires with a 40L fuel tank, 890 kg 5 door, 4 seater, parts are readily available at Plaza, Japanes are expensive, chinese are cheap, some mechanics also can use Bolan parts in Every.
Power windows, central locking, UV cutting glass, child lock, rear seatbelts are standard, front fog lights are optional, also available in permanent 4WD with 4 speed Auto and turbo K6A with 64PS.
12-16 km/l, ABS, rear wiper Driver and passenger Airbag standard.
Every GA is entry level, has airbags, locking and ABS all optional. UV glass and rear wiper standard, no fog lights and power steering, no power windows, drum brakes.
Every plus has a G13b SOHC 16v EFI with steering wheel tilt, SR optional, 14" allys tires, 5 doors, 7 seater bigger in size 980kg weight, also available with 4 speed auto, lower ground clearance to improve ride (155) with 85 PS engine, ventilated Disc, falling down dividing type rear seat with same size petrol tank.
There is no 6+ seater apart from old Pajero which I do not recommend, a good Every will cost between 2002-05 for 500k-750K for loaded one, look for a petrol one and run on petrol, especially the turbo is not happy with CNG at all.
Regards
