Results 1 to 5 of 5
Thread: EPS Light shows on - Toyota Passo 2005
    sazzadjn's Avatar
    Oct 2010
    chittagong
    Default EPS Light shows on - Toyota Passo 2005
    I'm Using a Toyota Passo 2005 1000 CC since 2 n half years.
    Recently sometimes EPS light is showing when engine is started and it doesnt go off and steering becomes haarder. I've checked in garage the tested with another reconditioned Controler but It didn't work out. Electroninc scanning showed ERROr C 1555 (MOTOR RELAY WELDING FAILURE). I'm in a quite lost situation, pls help what to do next. FYI when engine started ok (with no signal) it doesn't show up again until egine is restarted. means the light shows sporadically & whimsically. RGDS
    Site Banned Follow
    6037550's Avatar
    Jan 2009
    Sargodha
    29
    551
    i have drove one passo and it has one of best lightest steerings.but EPS light should turn off after 5 seconds of engine starts.hope u get solution
    automaster's Avatar
    Nov 2008
    185
    Default TOYOTA EPS Service Training
    Quote Originally Posted by sazzadjn View Post
    plz check this link may HELP you.
    http://www.timloto.org/download/pdf_...aDiagOnCar.pdf
    Try to change what you can't accept & try to accept what you can't change
    Newbie Follow
    ahmad.latif1's Avatar
    Jun 2013
    22
    had you got this problem solved or not?
    Newbie Follow
    anwartanvir's Avatar
    Oct 2016
    Default Passo 2008 EPS problem c1555
    I am having this problem for couple of weeks. EPS light comes up sometimes after starting the car and the steering gets harder. After couple of ignition it goes off and doesn't show up when the car is running. Scanning shows error c1555 motor relay welding failure. My garage is suggesting to replace eps motor and sensor. What should I do?
