Results 1 to 15 of 15
Thread: khyber experts help please
    wahabriaz's Avatar
    Nov 2009
    27
    290
    Default khyber experts help please
    i want downpiping and information on free flow exhaust in khyber and is it good and what is performance imoprove in khyber by free flow exhaust
    wahabriaz's Avatar
    Nov 2009
    27
    290
    same question for new swift
    Drug_Mafia's Avatar
    Aug 2007
    27
    1,452
    5 Post(s)
    @wahan
    Yes it does improves the performance but keeping in mind that it will also increae ur consumption too
    Explaination:
    As there will be no distortion in air passage from the engine to the cylincer it will increase ur initials hence increasing ur performance pickup......
    Using ur stock exhaust with free flow will help in producing less noise but installing after market exhaust will also increae ur sound........
    Depending on wht u need sound or just pickup....
    Suggestions:
    Before going for a free flow i wld recomend u to get ur sparl plugs changes get NGK Bpr5egp best for khyber's engine
    get plug wires 8mm orignal
    get ur coil changes to0
    m sure u wont need free flow......
    (*)Theres always a light at the end of a tunnel, just pray its not a train(*)
    Drug_Mafia's Avatar
    Aug 2007
    27
    1,452
    5 Post(s)
    n yes if u get free flow aoid reving ur car to high rpms it will result in decreasing ur cars engine life.........
    same applies to ur swift too
    wahabriaz's Avatar
    Nov 2009
    27
    290
    experts please help
    rozzzzz's Avatar
    Oct 2005
    21,925
    12
    140 Post(s)
    5 Thread(s)
    with stock setup..getting a down piping will give you low accel and top end advantage
    remove the cat and middle exhaust keep the exhaust tip stock..add an intake..
    maximum advantage i got on this setup.....
    MOTOR MANIACS ... An automotive service and repair workshop
    https://www.facebook.com/pages/Motor-Maniacs/721830141231922
    rozzzzz's Avatar
    Oct 2005
    21,925
    12
    140 Post(s)
    5 Thread(s)
    to much free flow and engine will have very low back pressure..result will be in damaged exhaust valve and low accel compare to stock
    wahabriaz's Avatar
    Nov 2009
    27
    290
    Quote Originally Posted by rozzzzz View Post
    rozz plz explain more
    wahabriaz's Avatar
    Nov 2009
    27
    290
    so now i want to rebuild khybers engine
    is it a good option or should i put new qabli engine in it
    wahabriaz's Avatar
    Nov 2009
    27
    290
    and i was using intake on khyber my mechanic said ur engine rings have got week becoz of this intake
    Zaheer_Zaidi's Avatar
    Feb 2010
    Rawalpindi
    28
    304
    first of all abt free flow i will say no keep its original exhaust bcz khyber engines cant bear ifree flow, its ma exp as i also used it....
    engine can be changed but if ur original engine is not bored more than 50% ( its the size of ring pistons ) than i prefer overhauling to 100% bt use genuine parts....
  12. #12
    wahabriaz's Avatar
    Nov 2009
    27
    290
    tell me is my mechanic saying truth about engine geting week becoz of using air inatke and what do u mean by engine bored???
    it is a engine not a human so how it is bored???
    Quote Originally Posted by Zaheer_Zaidi View Post
  13. #13
    Afzaalxaidi's Avatar
    Jan 2011
    Rawalpindi
    16
    Quote Originally Posted by wahabriaz View Post
    bro bored mean overhauling...i dont think so air intake effects the engine used it personally in my cultus nd it was working perfectly nd caused no effect on engine it was in perfect cndition
  14. #14
    wahabriaz's Avatar
    Nov 2009
    27
    290
    so my mechanic is lying it means
    Quote Originally Posted by Afzaalxaidi View Post
  15. #15
    Jan 2011
    Rawalpindi
    16
    yap bro bakwas karta hey
