Results 1 to 11 of 11
Thread: Dakha Start
    himmi_Pak's Avatar
    Nov 2010
    30
    1,861
    34 Post(s)
    Smile Dakha Start
    A.O.A
    How to Dakaha Start a Car ?
    Never did so , so tell me the way so that in-need i know how to do it
    thankyou
    takko's Avatar
    Dec 2005
    5,047
    17 Post(s)
    2 Thread(s)
    while moving forward..
    using 2nd gear for speed upto 30km/h]
    [using 3rd for max 60]
    Sit in a car,
    adjust ur mirrors,
    switch to 2nd gear and don't release the clutch and turn the switch position to "on"
    when u gain momentum release the clutch and at the same time try to start the car with the ignition .
    u can do the same with reverse and or first gear too..
    second gear is recommended [forward position] so there isn't any load on the gearbox
    p.s i have yet to try an auto tranny dhakka start
    people who use Highbeams.. once day would suffer too bigtime. People who drive slow on fast lanes, remember one day a vehicle carryin ur son, dad might get late to hospital coz people like u. underaged driving will land u in bigtime trouble one day or the other.. And the Blue indication light on ur speedometer denotes "High Beams"
    himmi_Pak's Avatar
    Nov 2010
    30
    1,861
    34 Post(s)
    second gear in fw postion doesnt understand
    onlyfaith's Avatar
    Sep 2010
    5,934
    8 Post(s)
    @takko!
    yes thats right!
    top documentaries " Tears of Gaza"
    dr3vil's Avatar
    May 2009
    11,930
    11
    201 Post(s)
    7 Thread(s)
    put the car in 2nd gear or 1st
    when u get enough motion start the car at the same time release the clutch and its all done
    Hanjiii Kaa Storeey Eehh !
    himmi_Pak's Avatar
    Nov 2010
    30
    1,861
    34 Post(s)
    thanks all
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,405
    131
    3991 Post(s)
    94 Thread(s)
    6
    Quote Originally Posted by takko View Post
    in an auto car while moving shut off the key while moving and the gear in D - nothing will happen becuase the transmission is not engaged at all, the oil pump is not turning - because the oil pump is driven directly from the engine.
    in other words - the only way to start an automatic transmission car with dead battery is jump start - if your starter failed, bad luck, remove and rebuild (word of advice - make a nice heavy jumper cable set and keep in your car - you may also help out other people with it)
    takko's Avatar
    Dec 2005
    5,047
    17 Post(s)
    2 Thread(s)
    why second gear..
    its simple.. by the time u have gained momentum, ur speed is usually around 30....
    sit in a car .. on a first gear and hit the speed of around 30-40.. u ll know why second gear is preferred
    asad_scorpio21's Avatar
    Mar 2007
    Rawalpindi
    38
    4,537
    agar aagay charai hai to reverse gear men start kar lo , kiyonkay charai par dakha lagana mushkil hoga.
    iLLDuDe786's Avatar
    Feb 2009
    New York City
    11,213
    not possible :/
    khanji_143's Avatar
    Dec 2004
    29
    1,005
    3 Post(s)
    Quote Originally Posted by iLLDuDe786 View Post
    not possible :/
    +1
    Inappropritiate Language. Removed
Tags for this Thread
