Page 3 of 14 FirstFirst 1234513 ... LastLast
Results 41 to 60 of 263
Like Tree89Likes
Thread: Coolant comparison NASA vs OSAKA vs DK vs GS vs ZIC
    Horse_rider's Avatar
    Sep 2009
    30
    1,364
    3 Post(s)
    Default Coolant comparison NASA vs OSAKA vs DK vs GS vs ZIC
    Please compare the quality of the following coolants and what is your rating for them, please give marks out of 10.
    for example:
    NASA = 10
    OSAKA = 10
    DK = 10
    GS = 10
    ZIC = 10
    CALTEX=10
    PYRO MADE IN LAHORE=10
    what is your own experience? if you want to add more coolant to the list please update the list.
    Thanks
    현대 애인
  2. #41
    cracked's Avatar
    Mar 2009
    Rawalpindi
    28
    2,963
    35 Post(s)
    Answers.com - What increases boiling point of coolant
    bro coolant dont increases temp limit,pressure does...
    follow the link,its plain n simple..
    plus both bottles were kept in freezer with same conditions,like both were opened from their faces,bottle caps were on but inside seal was broken !
    REAL men drive manual cars!
  3. #42
    Sep 2009
    30
    1,364
    3 Post(s)
    Brother no offense to you, it is just discussions fro me, for you, and for other members.
    What, exactly, does Antifreeze do in a car? - Yahoo! Answers
    in fact every liquid have different boiling points and freezing points, the water boiling point is 100 Degree c. while the chemical formula of coolants and antifreez or such that there boiling points more than water (100c) and freezing point are less than water just because of its chemical formula.
    Thanks.
    현대 애인
  4. #43
    ahsan1702's Avatar
    Mar 2006
    27
    4,032
    Umm.
    Coolant DOES change the boiling and freezing point of the liquid. Your own NASA coolant test proved that. I dont exactly remember but if one extreme point (i.e. freezing) is changing than so will the other (i.e. boiling). Something about thermal capacity.
    If NASA wont freeze in your freezer, which is obviously below 0c ... it wont boil at 100c either.
    1st Generation Integration
  5. #44
    Sep 2009
    30
    1,364
    3 Post(s)
    @all
    please share more experiences about coolants and its price with performance. As extreme summer is on the way next. So every member will get help from here. I am using DK and it is good so for. After CRACKED experience of nasa. I am also willing to switch to nasa. Do't know whether DK is as good as nasa or not? Anyone know?
    현대 애인
  6. #45
    fasfas's Avatar
    Oct 2007
    Wah cantt
    38
    359
    These NASA, OSAKA etc. are effective for SHORT life, sooner decompose and lose their power. but work for a month you can say. in summer might be lesser.
    genuine coolants are costlier than per litre engine oil even. not for fully synth.
  7. #46
    cracked's Avatar
    Mar 2009
    Rawalpindi
    28
    2,963
    35 Post(s)
    my bad...coolant does increase high end temp ,pressure plus coolant makes it boil it higher temp..
    i was half wrong..sory
  8. #47
    ahsan1702's Avatar
    Mar 2006
    27
    4,032
    Well as per my experience, in the usually available stuff nothing beats Caltex.
    Ive seen them put on cars with small radiators such as Khybers etc ... turbocharged cars, both stock turbo and aftermarket ... stock cars.
    That coolant is awesome. Its expensive but if you want an year of sukun, Caltex is the way to go.
  9. #48
    asad1's Avatar
    Aug 2005
    30
    2,707
    3 Thread(s)
    this is wat we call a real coolant it seems like oil and work awesome
    Coolant comparison NASA vs OSAKA vs DK vs GS vs ZIC -226796
  10. #49
    Sep 2009
    30
    1,364
    3 Post(s)
    Till now i think the rating is going like this
    1st prize to Caltex
    2nd prize to ZIC, TOYOTA, HONDA
    3rd prize to NASA
    4th prize to all other coolants
    but i think more replies will clarify the positions in more bright way. so keep the ideas coming.
    Thanks
    현대 애인
  11. #50
    Faisal_RX8's Avatar
    Sep 2009
    Rawalpindi
    31
    1,098
    Default Zic Coolant
    Got Zic coolant 4L pack for Rs.1050
    Coolant comparison NASA vs OSAKA vs DK vs GS vs ZIC -227369 Coolant comparison NASA vs OSAKA vs DK vs GS vs ZIC -227370
    " Hope for the best & Prepare for the worst. "
  12. #51
    Sep 2009
    30
    1,364
    3 Post(s)
    @faisalRX8
    Please share ur exp after usage.
    현대 애인
  13. #52
    Faisal_RX8's Avatar
    Sep 2009
    Rawalpindi
    31
    1,098
    i will share my experience after use.
  14. #53
    cracked's Avatar
    Mar 2009
    Rawalpindi
    28
    2,963
    35 Post(s)
    i went to a shop,reliable shop and asked price of caltex coolant..
    he was sayin 690 for one liter..
    i mean thts too much innit???
  15. #54
    Sep 2009
    30
    1,364
    3 Post(s)
    Quote Originally Posted by cracked View Post
    you should get caltex only from caltex outlet at their petrol pumps, don't even get it from the most reliable shop, because you will never get it better than caltex own outlet.
    현대 애인
  16. #55
    cracked's Avatar
    Mar 2009
    Rawalpindi
    28
    2,963
    35 Post(s)
    i wasnt there to buy it..just stopped by and asked price..
    im thinkin to get zic coolant btw!
  17. #56
    Faisal_RX8's Avatar
    Sep 2009
    Rawalpindi
    31
    1,098
    690 for caltex is too much.
  18. #57
    cracked's Avatar
    Mar 2009
    Rawalpindi
    28
    2,963
    35 Post(s)
    faisal
    whr did u buy this zic coolant
    and 1050 is price right???
    for 4 liter pack
  19. #58
    salman_m5's Avatar
    Nov 2004
    Melbourne
    31
    2,383
    bought caltex coolant 2 bottles for 1400rs
  20. #59
    Faisal_RX8's Avatar
    Sep 2009
    Rawalpindi
    31
    1,098
    faisal
    for 4 liter pack
    i bought it from a zic distributor which is located near rawalpindi madical college retail price is around 1200 but they gave me at 1050.
  21. #60
    Subzwari's Avatar
    Mar 2009
    36
    415
    @Faisal_Rx8
    is it pre-diluted ? if yes than what ratio? is it glycol based ?
    would appreciate if you could post some readable closeups of the stickers. thanks
Tags for this Thread
