Results 1 to 3 of 3
Thread: Is 20 Valve engine 5 cylinder ?
    Badpigs's Avatar
    May 2009
    26
    2,435
    55 Post(s)
    5 Thread(s)
    Default Is 20 Valve engine 5 cylinder ?
    Aoa
    ......guys im working on a project and just wanted to know that is a 20 valve engine 5 cylinder or not ? is it possible to have 4 cylinder 20 valve engine ....if yes then how to accomodate 5 valves per cylinder ? ....how many inlet valves and how many outlet valves wud be there in it ?
    LIVE 4 NOTHING .........................BUT DIE 4 SOMETHING
    whisky's Avatar
    Jan 2006
    28
    2,201
    6 Post(s)
    If what you're referring to is the Toyota 4AGE BT/ST then no, it's not a 5 cylinder engine. It's a 4 cylinder engine with 5 valves per cylinder thus effectively giving it 20 valves with 3 on the intake side and 2 on the exhaust per cylinder.
    My engine history; CB70 -> 4EFTE -> D15B VTEC -> D16Y6 VTEC -> 1JZ-GTE
    Badpigs's Avatar
    May 2009
    26
    2,435
    55 Post(s)
    5 Thread(s)
    ohh kkk ...thnx buddy ......
