Results 1 to 5 of 5
Thread: Honda B16A Price
    FaizAsim93's Avatar
    Jun 2011
    15
    Default Honda B16A Price
    Hi everyone.I want ask you all about the price of honda b16a.Im looking for a decent one with less mileage.And i also want to ask you all the price of a B18c5.Please suggest me for which one should go in a daily driven car with A/c.
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,405
    131
    3991 Post(s)
    94 Thread(s)
    6
    B18 daily driven - A/C, workable but would you like it?
    the B series engines shine when you gun them to redline - and when they are bouncing the redline - they are swigging fuel faster than a jet.
    btw - they are very scarce in Pakistan now - as every tom, dick, harry, freddie, mama, chacha, dada, dadee, nana, nanee - has transplanted a B16 or B18 into anything that resembles a car.
    Your best option would be to talk to someone who imports engines - and buy one complete with tranny and electrics - it would land you about more than 120,000 dented to your wallet
    FaizAsim93's Avatar
    Jun 2011
    15
    Im going for A/C because sometimes the summer heat is unbearable.I will be driving it in a normal way and would be hitting the redline on the track.The car will be a civic EG or EF.A good engine would cross even 150k and it would not be a problem for me.
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,405
    131
    3991 Post(s)
    94 Thread(s)
    6
    good - then go for it, the A/C is pretty simple to connect up to your original car - the compressor discharge pipe only needs to be made from scratch.
    The ECU wiring would need to be done properly for the A/C compressor to engage along with the automatic idle control the IACV provides. Run the original compressor that comes bolted to the B series engines - as the engine is a high rpm engine the compressor is matched to it, putting in a sanden would be bad news as it would not like to be spun to 8000 rpm.
    N2O
    N2O is offline
    N2O's Avatar
    Nov 2005
    2,317
    15 Post(s)
    b16 when tuned on wideband on lower cam(before vtec) can result in a much favourable economy while still maintaining torque in the lower rpms,tried and tested on a k24a2 similarly. Just need to know the lean limit of afr
    knowledge is horsepower
