Results 1 to 5 of 5
Thread: Cultus fuel tank filter problem
    bilawalx's Avatar
    Mar 2011
    24
    253
    Default Cultus fuel tank filter problem
    Hey guys
    I know very little about suzuki,
    So anyways i took out a little petrol from a cultus by inserting a pipe inside its fuel tank from where the petrol goes in, i took about 2-3 L. Now my friend tells me that i might have damaged a filter (jaali) cause i inserted a pipe in it. Is there anysort of jaali there ?
    Cause the only filter related to petrol i know is the fuel filter which is located inside the engine.
    itsgumbys's Avatar
    May 2007
    707
    11 Post(s)
    ^^ in cultus the only fuel filter is not inside engine, its in fuel tank.
    yes, its a possibility of damaging the "jali" while doing such act.
    regards,
    gumby.
    scorpion80's Avatar
    May 2007
    36
    4,320
    11 Post(s)
    .. nothing is damage sir ..
    scorpion80's Avatar
    May 2007
    36
    4,320
    11 Post(s)
    u put a pipe from the place where u fill the petrol ??
    actual filter is on the sucking area of fuel pump which is inside the fuel tank ... its like ceramic or some hard filter which cannot get damaged so easily...
    next time u need a petrol try to get it from the engine bay .. by pulling pipe out from the carb .. by ignition on
    bilawalx's Avatar
    Mar 2011
    24
    253
    Yeah i inserted it from where we fill the petrol.
    I see so there is some kind of filter (jaali) down there...i think i should get it checked, just in case.
    Thanks alot guys !
