Page 1 of 3 123 LastLast
Results 1 to 20 of 47
Like Tree5Likes
Thread: OBD II Scanner Information
    umair2203's Avatar
    Jan 2010
    3,984
    107 Post(s)
    5 Thread(s)
    Question OBD II Scanner Information
    Dear All,
    I need answer to following Question
    1. Is our 8th Generation Civic is OBD II certified ?
    2. I am trying to import an OBD scanner for 8th Generation Civic, I have come across couple of options
    a. Ultra Gauge ( UltraGauge Automotive Information Center and OBDII Scan Tool )
    Video :- UltraGauge, a mini-review - YouTube
    b. Kiwi MPG ( PLX Kiwi MPG - MPG Meter, Trip Computer, Engine Check Scan Tool, OBD2 OBDII Gauge )
    Video :- PLX Kiwi MPG - MPG Meter, Trip Computer, Scan Tool, OBDII OBD2 Gauges - YouTube
    c. Scan Gauge ( ScanGaugeE : Linear Logic - Home of the ScanGauge )
    3. Please guide me that if they all are compatible with 8th Gen Civic and which of them is more reliable and easy to use.
    Also, tell me if you have something better. I will Appreciate the concern.
    Cheers
    Education is not any Degree or Certificate.
    Education is the our attitude,language & behaviour with others in life............!!!!
    xsxd's Avatar
    Jun 2007
    593
    2 Post(s)
    Check your car for the DLC port. It should be under the driver side dash somewhere. Other PW members will better guide you. If its a 16 pin port, then you're good to go. Any OBD2 scanner (CAN based) will work just fine. If it's not 16pin, then you need to find an adequate adapter.
    A safer bet is using OBD2-ELM327 scanners, which are compatible with most vehicles.
    For my Civic 99, the DLC port has 3 pins and is located with the ECU (passenger side kick panel).
    A Bluetooth enabled scanner will provide greater flexibility in the type of displays you need... for example, it can connect to your car pc or an app on your iphone or android smartphone. Personally I prefer a BT OBD2-ELM327 scanner.
    All of the scanners you have listed are compatible. It is just a matter of what functionality and display options you want from your scan tool. I prefer to set my own display options therefore ultragauge and scangauge seem too limited plus they are wired directly to the ecu and i dont like visible wires/cables in my car.
    If you're okay with wired units, get ultragauge if you want more information displayed at a time; or scangauge II if you want a more disrcrete display.
    Not an expert myself, but I've been looking around myself for one of these... and I decided on a BT tool... or if that doesnt work, then Ultragauge.
    umair2203's Avatar
    Jan 2010
    3,984
    107 Post(s)
    5 Thread(s)
    Thanks @xsxd
    The dongle you suggested is goof but the problem is you gona need a smart phone for it. I needed something dedicated.
    Wired device is not my first preference also, If I can find something dedicated, some stand alone Bluetooth Module .... That will serve the purpose.
    xsxd's Avatar
    Jun 2007
    593
    2 Post(s)
    Quote Originally Posted by umair2203 View Post
    Thanks @xsxd
    here's a thought... if you can put up a cradle/mount for a 7" device, get a cheap android device (APad etc) for roughly 15,000 and install "Torque" on it. I saw a decent device with a capacitive touchscreen (looks a lot better and is a lot more responsive).
    Otherwise you can find a suitable place for Ultragauge, drill up your dash a bit, and neatly fix up the tool while hiding all wires within the dash.
    xsxd's Avatar
    Jun 2007
    593
    2 Post(s)
    I have a 1Din slot empty in my civic and am looking to use that somehow.
    umair2203's Avatar
    Jan 2010
    3,984
    107 Post(s)
    5 Thread(s)
    Quote Originally Posted by xsxd View Post
    Bro the civic is with Honda's Offered Navigation so there is no place left but I will like to know more about Apad etc
    I think I pod would be a better option then Apad, if someone is spending 15K.
    Some Device like UltraGauge with a Bluetooth Interface would be perfect !
    xsxd's Avatar
    Jun 2007
    593
    2 Post(s)
    stick to ultragauge then. an expensive technique wud be the replace your navi system with something that can use software like centrafuse. but that's a long shot if you dont know what you're doing.
    xsxd's Avatar
    Jun 2007
    593
    2 Post(s)
    Apad is a chinese android tablet. the one i saw was with a 7" capacitive screen. 800mhz but its more than enuff for a car pc unless HD content is required. Rs.15,000. Havent tried it though. I assume it has battery issues like all the other chinese devices.
    Bilaltq's Avatar
    Mar 2004
    Select City
    26
    10,311
    10 Post(s)
    I second the Bluetooth OBDII ELM327 option. I've been using it for quite some time now, and it's really handy for clearing fault codes on the go, and pretty much gives you an active realtime telemetry on your engine. Probably the best $25 (in total) I've spent!
    This comment was made by a person with a tested IQ of negative 9.
    umair2203's Avatar
    Jan 2010
    3,984
    107 Post(s)
    5 Thread(s)
    any member having any experience with any other device ??
    PKTUN's Avatar
    Oct 2011
    Khuzdar
    1,067
    35 Post(s)
    3 Thread(s)
    idehr in khuzdar we have Launch X431 and it has 16 different connectors for almost every car & truck in our fleet from saab, volvo, scania (basically all truck diagnostic we do is via x431) and from to-ta to sajuki veetara. computer 1 hai 16 plug sath hai.
  12. #12
    yasirsa's Avatar
    Apr 2009
    Peshawar
    38
    1,388
    6 Post(s)
    my exi 2002 was obdII and i imported that scaner . and it was working fine. anyways am 80% sure ur rebon will be obdII
  13. #13
    MK77's Avatar
    Nov 2009
    353
    6 Post(s)
    @poster:
    All your choices will work on your car. The best i have used is PlxKiwi for Iphone. It is a great tool and on Iphone it adds so much convenience.
  14. #14
    umair2203's Avatar
    Jan 2010
    3,984
    107 Post(s)
    5 Thread(s)
    Quote Originally Posted by MK77 View Post
    @poster:
    For that you need to have an Iphone first and it is not a dedicated tool. No doubt that it is good but I need something dedicated.
  15. #15
    khurram_aziz's Avatar
    Jan 2011
    Faisalabad
    39
    2,466
    6 Post(s)
    ScanGuauge II will fit perfectly into Civic's dash; the sunglass box under the AC!
  16. #16
    umair2203's Avatar
    Jan 2010
    3,984
    107 Post(s)
    5 Thread(s)
    can anybody help me import the device ???
  17. #17
    xsxd's Avatar
    Jun 2007
    593
    2 Post(s)
    check OLX or similar websites... i recall seeing an ELM327 scanner for 9000 (which is too pricey IMO).
    Civic '99 VTi Oriel D15B 3-Stage VTEC A/T
    JVC KD-G645, Sony XS-GTR1720S, Pioneer TS-D691S, Rogers RA-6400 4CH, Addzest APA2100 2CH
  18. #18
    bilalmahmood154's Avatar
    Jan 2012
    39
    91
    Quote Originally Posted by Bilaltq View Post
    can u please tell me how u bought this device.....
  19. #19
    Jan 2012
    39
    91
    Bluetooth Wireless OBD2 Reader
    check this link as well
  20. #20
    MK77's Avatar
    Nov 2009
    353
    6 Post(s)
    If anyone need OBDII dongle.....confirm with payment till 15th Feb, 2012....I am receiving that and other items in early March. Total cost is $30 (courier to city charges not included).
Tags for this Thread
