Results 1 to 6 of 6
Like Tree1Likes
  • 1 Post By rozzzzz
Thread: Vitz Engine replacement & No Engine Number on Imported Vitz
    yousafmalik's Avatar
    Apr 2008
    37
    11
    Exclamation Vitz Engine replacement & No Engine Number on Imported Vitz
    AoA All,
    I would like to get some advice regarding replacement of engine for a toyota vitz.
    I own a 2000 model, registered 2006 toyota vitz, recently it started giving trouble and heating up after all other checks failed its head was opened up to find lots of damage to the head and it was causing pressure to build up and over heating. The advice is to get the head replaced.
    I colleague of mine asked me to call up a person who owns a workshop here in lahore and also is an importer of spares as well. That person advised me that instead of getting the head replaced which will cost me around 10 - 12 k (including labor & other material) i should simply get the engine replaced (which will cost me around 18-20k ) when i said that i would also go through the hassle to get the registration docs modified the said that "THESE IMPORTED CARS DO NO HAVE ANY ENGINE NUMBER and you wont need any change in the docs" This is a surprise to me as i checked my car docs and it does state an Engine Number.
    Can any member give an advice regarding this issue. Is it true about these cars having no engine number????
    aqs29's Avatar
    Mar 2006
    Hyderabad
    3,129
    16 Post(s)
    Each car has an engine number
    aqs29's Avatar
    Mar 2006
    Hyderabad
    3,129
    16 Post(s)
    That importer just wants to make a quick buck
    rozzzzz's Avatar
    Oct 2005
    21,925
    12
    140 Post(s)
    5 Thread(s)
    every engine has a number....it will cost around 4k to get on the book
    in 20k u will only get the head and block ..rest will be from the old setup
    MOTOR MANIACS ... An automotive service and repair workshop
    https://www.facebook.com/pages/Motor-Maniacs/721830141231922
    tyrone_40's Avatar
    Jan 2005
    Other
    1,600
    13 Post(s)
    Would the value of the car decrease if the engine is replaced?
    sjameel's Avatar
    Aug 2010
    33
    316
    14 Post(s)
    Replace the entire engine. That will cost you in karachi 25K all expenses included. Trust me you'll feel the difference and your car will be good for another 100k Kms. When engine is f****d get rid of it.
