Results 1 to 4 of 4
Like Tree1Likes
  • 1 Post By capsat
Thread: Toyota Duet/ Daihatsu Storia Mechenic/Electrition
    asadilyas's Avatar
    Oct 2008
    Peshawar
    Default Toyota Duet/ Daihatsu Storia Mechenic/Electrition
    Hello, I have changed my engine assembly and gearbox of my Storia/Duet 99 but still I have a problem. When I shift it to any gear except P and N, the RPM falls down and the engine start vibration as if the foundation is broken. I checked each and everything but unable to trace the problem. The auto chock also works sometimes, I went to few electritions, they run a diagnostic test over it but still unable to solve. Will somebody kindly tell me any good machenic or electrition for Storia/Duet in Peshawar or Rawalpindi/Islamabad. Will be really thankful.
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,597
    31
    6
    1018 Post(s)
    19 Thread(s)
    5
    6
    problem is not electronic it is adjustment of throttle cable which connects to an actuator in the auto transmission. adjust throttle cable that at idle rpm actuator is dis-engaged.
    also check for the front & rear engine mounting
    - www.crackwheels.com - A skilled Dictator is much more beneficial to Country......than a Democracy of Ignorant people
    asadilyas's Avatar
    Oct 2008
    Peshawar
    Thanks for the reply, I have checked the mountings, all the 3 mountings are in well condition, can you please tell me how to adjust this throttle cable ? I think I have to do it by my own because in Peshawar there is no such machenic or electrition who can resolve this problem.
    Newbie Follow
    fahdoaffi's Avatar
    Nov 2007
    33
    Will somebody kindly tell me any good machenic for Storia/Duet in Karachi
Tags for this Thread
