Just replaced the stock AGS battery of my 2008 civic. it lasted for 4 great yrs. now opted for maintenance free battery Hankook 60AMP (6 months free replacement). Hope it lasts the same amount or more
total cost 6000
old battery adjustment 800
Final cost 5200
- one more informative point for battery replacement procedure.
the battery guy started the car, disconnected the old battery and then reconnected the new battery.
so this way all settings remained save & we were also safe from ecu resetting or rough idle problems or any other problem which sometimes occurs when you disconnect battery. this procedure is normally done when you have trakker installed but you can also opt for this procedure i personally think its safe and more reliable for advance cars.
BUT MAKE SURE DURING THE PROCESS YOUR NEGATIVE & POSITIVE TERMINALS DOESN'T COLLIDE WITH EACH OTHER otherwise
