Results 1 to 6 of 6
Like Tree1Likes
  • 1 Post By ijazbaig
Thread: Suzuki Liana Rxi 2006
    ijazbaig's Avatar
    Oct 2010
    50
    Default Suzuki Liana Rxi 2006
    Asslamo Alykum
    I need Owner's manual/User guide of Suzuki Liana Rxi 1.3
    Please help
    Thanks, Jazak Allah
    Ijaz Baig
    Skill's Avatar
    Aug 2009
    Select City
    7,885
    94 Post(s)
    40 Thread(s)
    Quote Originally Posted by ijazbaig View Post
    Asslamo Alykum
    Please help
    Thanks, Jazak Allah
    Ijaz Baig
    i have one in pdf,but it is big in volume,hectic job to attach it due to slow connection these days
    https://www.facebook.com/skillgrafik
    jamfazal's Avatar
    Dec 2011
    Other
    24
    I think you need to search useful and actionable data for your recommendation and face book platform enables you to make your website for marketing for more social and face book has published a best practice guide for your platform for marketing then you achieve your goal.
    [url=http://www.rakca.com/dubai-company.php/]Dubai Company[/url
    [url=http://www.rakca.com/services/offshore/why/]Rakca.com[/url
    ijazbaig's Avatar
    Oct 2010
    50
    Quote Originally Posted by Skill View Post
    Mr. Skill
    Thank you for reply, please send me periodic maintenance pages, the whole book may be received later.
    Jazak Allah
    Ijaz
    Skill's Avatar
    Aug 2009
    Select City
    7,885
    94 Post(s)
    40 Thread(s)
    Mr. Skill
    Jazak Allah
    Ijaz
    Maintenance Schedule
    Maintenance Schedule Under Normal Driving Conditions
    NOTE:
    • This interval should be judged by odometer reading or months, whichever comes first.
    • This table includes service as scheduled up to 90,000 km (54,000 miles) mileage. Beyond 90,000 km
    (54,000 miles), carry out the same services at the same intervals respectively.
    Interval
    Km (x 1,000) 15 30 45 60 75 90
    Miles (x 1,000) 9 18 27 36 45 54
    Months 12 24 36 48 60 72
    ENGINE
    Drive belt – – I – – R
    Valve lash (clearance) – I – I – I
    Engine oil and oil filter R R R R R R
    Engine coolant – – R – – R
    Exhaust system – I – I – I
    IGNITION SYSTEM
    ✱Spark plugs When
    unleaded
    fuel is used
    Vehicle without
    HO2S
    Nickel plug – R – R – R
    Iridium plug – – – R – –
    Vehicle with
    HO2S
    Nickel plug – – R – – R
    Iridium plug Replace every 105,000 km (63,000 miles) or
    84 months
    When leaded fuel is used, refer to “MAINTENANCE RECOMMENDED UNDER SEVERE
    DRIVING CONDTION” in this section.
    FUEL SYSTEM
    Air cleaner filter Paved-road I I R I I R
    Dusty conditions Refer to “MAINTENANCE RECOMMENDED
    UNDER SEVERE DRIVING CONDITIONS”
    in this section.
    Fuel lines and connections – I – I – I
    Fuel filter Replace every 105,000 km (63,000 miles)
    Fuel tank – – I – – I
    EMISSION CONTROL SYSTEM
    ✱PCV valve Vehicle without HO2S – – I – – I
    Vehicle with HO2S – – – – – I
    ✱Fuel evaporative emission control system – – – – – I
    NOTE:
    • “R” : Replace or change
    • “I” : Inspect and correct, replace or lubricate if necessary
    • For Sweden, items with ✱ (asterisk) should be performed by odometer reading only.
    • For spark plugs, replace every 50,000 km if the local law requires.
    • Nickel spark plug : BKR6E-11 (NGK) or K20PR-U11 (DENSO)
    • Iridium spark plug : IFR6E11 (NGK)
    MAINTENANCE AND LUBRICATION 0B-3
    Interval
    BRAKE
    Brake discs and pads (thickness, wear, damage) I I I I I I
    Brake drums and shoes (wear, damage) – I – I – I
    Brake hoses and pipes (leakage, damage, clamp) – I – I – I
    Brake fluid – R – R – R
    Brake lever and cable (damage, stroke, operation) Inspect at first 15,000 km (9,000 miles only)
    CHASSIS AND BODY
    Clutch (fluid level, leakage) – I – I – I
    Tires (wear, damage, rotation) /wheels (damage) I I I I I I
    Suspension system (tightness, damage, rattle, breakage) – I – I – I
    Steering system (tightness, damage, breakage, rattle) – I – I – I
    Drive shaft (axle) boots/Propeller shafts (4WD) – – I – – I
    Manual transaxle oil (leakage, level) (I : 1st 15,000 km only) I – R – – R
    Automatic transaxle fluid Fluid level – I – I – I
    Fluid change Replace every 165,000 km (99,000 miles)
    Fluid hose – I – I – I
    Transfer oil (4WD A/T) (leakage, level) I – I – I –
    Rear differential oil (4WD) (leakage, level) (R : 1st 15,000 km
    only)
    R or I – I – I –
    All latches, hinges and locks – I – I – I
    Power steering (if equipped) I I I I I I
    NOTE:
    • “I” : Inspect and correct or replace if necessary
    0B-4 MAINTENANCE AND LUBRICATION
    Maintenance Recommended under Severe Driving Conditions
    If the vehicle is usually used under the conditions corresponding to any severe condition code given below, IT IS
    RECOMMENDED that applicable maintenance operation be performed at the particular interval as shown in the
    following table.
    Severe condition code :
    A : Repeated short trips
    B : Driving on rough and/or muddy roads
    C : Driving on dusty roads
    D : Driving in extremely cold weather and/or salted roads
    E : Repeated short trips in extremely cold weather
    F : Leaded fuel use
    G : – – – – –
    H : Towing a trailer (if admitted)
    Severe
    Condition Code
    Maintenance
    Maintenance
    Operation
    Maintenance Interval
    – B C D – – – – Drive belt
    I
    Every 15,000 km
    (9,000 miles) or 12 months
    R
    Every 45,000 km
    (27,000 miles) or 36 months
    A – C D E F – H Engine oil and oil filter R
    Every 5,000 km
    (3,000 miles) or 4 months
    – – C – – – – – Air cleaner filter ✱1
    I
    Every 2,500 km
    (1,500 miles)
    R
    Every 30,000 km
    (18,000 miles) or 24 months
    A B C – E F – H Spark plugs
    Nickel spark plug
    R
    Every 10,000 km
    (6,000 miles) or 8 months
    Iridium spark plug
    R
    Every 30,000 km
    – B C D – – – H Wheel bearings I
    Every 15,000 km
    – B – D E – – H Drive shafts and propeller shafts (4WD) I
    Every 15,000 km
    – B – – E – – H
    Manual transaxle oil, transfer oil (4WD A/T)
    and differential oil (4WD)
    R
    Every 30,000 km
    – B – – E – – H
    Automatic transaxle fluid R
    Every 30,000 km
    Automatic transaxle fluid hose I
    Every 15,000 km
    NOTE:
    • ✱1 : Inspect more frequently if the vehicle is used under dusty conditions.
    ijazbaig's Avatar
    Oct 2010
    50
    NOTE:
    Interval
    ENGINE
    IGNITION SYSTEM
    ✱Spark plugs When
    unleaded
    fuel is used
    Vehicle without
    HO2S
    Vehicle with
    HO2S
    84 months
    FUEL SYSTEM
    in this section.
    NOTE:
    Interval
    BRAKE
    CHASSIS AND BODY
    only)
    R or I – I – I –
    NOTE:
    following table.
    F : Leaded fuel use
    G : – – – – –
    Severe
    Condition Code
    Maintenance
    Maintenance
    Operation
    I
    Every 15,000 km
    R
    Every 45,000 km
    Every 5,000 km
    I
    Every 2,500 km
    (1,500 miles)
    R
    Every 30,000 km
    Nickel spark plug
    R
    Every 10,000 km
    Iridium spark plug
    R
    Every 30,000 km
    Every 15,000 km
    Every 15,000 km
    – B – – E – – H
    R
    Every 30,000 km
    – B – – E – – H
    Every 30,000 km
    Every 15,000 km
    NOTE:
    Asslamo Alykum
    Dear Mr. Skill
    Thank you very much for the help.
    Jazak Allah
    Ijaz Baig
